EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Sat Jun 17, 2017 10:32 am
I would think there really is an issue, either with the CAT itself or the sensor after it. Sensors go bad with age, and if you're interested in some troubleshooting instead of just buying parts, I would swap the sensor 2 between the passenger & driver sides.
If you start getting P0420 instead, then your sensor is suspect. You might end up clearing it just by unplugging and reseating the plugs for a better connection.
If the same code comes, then the catalyst efficiency might be truly compromised and it's time to go back through the troubleshooting steps in the FSM.
*Personally, I don't clear codes unless I am making a change to track with it. In fact, for daily drivers and cars I drive often, I just make the change and leave the code to reset itself or change to whatever new code is.
