reving problem
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
well first this is my set up as of right nowrebuilt KAe stock spec internals-stock injecter-stock MAF-T04e garret turbo 60trim-duel n1 isis cat back-JGS turbo mani-Tial 34mm WG-emisson removel (everything except IAC)
is not a complete build but it is as of now and i do have more part to put in
here is the problem if i full thorttle it, the car wont pass 3000 rpm and start spiting fireballs like a bee R limiter
but if i go slow it will do that just fine it'll redline no prob
i doubt the maf will maxout just with this set up
neverlift
I hope you have something to increase teh flow of the fuel injectors, or that is probably your problem, full throttle=boost, afr(on a wideband) should be in the 11:1 maybe a hair leaner.
WDRacing
chaosli
99 mazda miata
93 bmw 325i RIP
neverlift wrote:I hope you have something to increase teh flow of the fuel injectors, or that is probably your problem, full throttle=boost, afr(on a wideband) should be in the 11:1 maybe a hair leaner.
your probally right i have a aem ems i just need to put it in and set it up as well as bigger injectors that i need to set up
WDRacing
Dude...quit screwing around before you blow your motor. It's probably already damaged. Do a compression test.
You can't just add boost to a car and expect it to work.
neverlift
WDRacing wrote:Dude...quit screwing around before you blow your motor. It's probably already damaged. Do a compression test.
You can't just add boost to a car and expect it to work. Unless you crank the base fuel pressure up into the sky...
altered.
Doya
Car: '95 240sx KA-T
At least get an FMU
chaosli
99 mazda miata
93 bmw 325i RIP
i do have a ems
RustspecS13
Car: '74 260z and '88 300zx turbo
Well according to you its not installed.
I have 20 junkyard injectors from rx7's and dsm's, and a rx7 turbo. It doesn't mean my rb20 and ka24e are both turbo'd and making 600WHP.
Install your AEM and get it tuned before you blow your motor.
~Alex
