rogoman »
https://forums.nicoclub.com/rogoman-u37451.html
Tue Jun 19, 2007 9:43 am
How did you do the DOHC install? Here are the steps that need to be performed:
-The accelerator cable needs to be changed. The sohc cable is shorter and doesn't have enough travel.
-The power steering lines need to be changed over.
-The tachometer will need to be changed out to a dohc s13 unit. the signal is different between the two. The tach can be removed from the cluster, or the whole cluster can be changed.
-The dash gauge water temperature sensor from the SOHC engine needs to be used. For some reason the resistance is different. If you use the stock sensor from the DOHC engine, it will register on the gauge as being higher than with the SOHC unit.
-Go ahead and remove the coil assembly from the car. the SOHC one won't work on the DOHC engine.
-The engine wiring harness and ECU will need to be replaced with one for the DOHC engine. The dash connector will need to be cut off the SOHC engine harness (where it meets the dash harness), and soldered to the DOHC engine harness in the same location. There will be wires that are left floating so don't worry. All the wires that need to be connected will be color matched. For example: just put red to red, and white to white, ect.
-The mafs from the DOHC car will need to be used. the SOHC mafs won't work with the DOHC ECU.
-The s13 ps pump has to have s13 ps lines.
