Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Thu Apr 15, 2004 4:33 pm
I recieved my PLX M-300 wideband system today to replace my LM-1. i ordered it from streetrays.com. Comparing to the LM-1
PRO's:much nicer, smaller, easier to mount dispaly (main reason for buying)Turns on and off with the car (LM-1 has to be turned on/off manually)display is red (matches my car)Comes with wires to hook up to piggybacks and standalones
CON's:doesnt dataloghas a power and ground wire that need to be hooked up (LM-1 uses a cigarette lighter plug)at 20:1+ afr it jstu reads LEAN at 9:1- reads RICH and during deceleration when all u get is o2 it reads AIR (not really a big deal but LM-1 will still give u numbers even tho by then they arent too accurate)doesnt come with an o2 sensor bung and plug (LM-1 does)
all in all i like this one alot more jsut because of the display and that u dont have to turn it on and off all the time.
