Pumaking »
https://forums.nicoclub.com/pumaking-u22322.html
Fri Oct 14, 2005 1:48 pm
Review of the Megan Racing S13 Street Coil-Overs.
First off let me give you an idea of how my ride was before I upgraded. I currently own a 1990 240sx SE hatchback with S13 front end, 180sx tail lights and pretty much stock everything else at the moment (prepping new motor for transplant). Before the upgrade I had the original factory suspension with blown rear struts. My ride was horrible I had extreme case of wheel hop when I would take some turns, even on hard braking my rear end would be hopping like crazy, also my car when hitting a bump would weave left and right kind of like being on a shoe with 1 spring, and lastly at 55-60mph my steering wheel would shake. Now I have only experienced 5 rides with different suspension, 3 were stock suspension and 1 was a aftermarket Omni Coil-Over suspension on a 1992 Honda Civic hatchback with 10kg front and 8kg rear spring rates, the last one was my car with the Megan Racing Street.
First I would like to say the package came nicely secure wrapped and strapped as to keep my package free from any freight damage. Inside were a manual, a warranty card, a sticker and a pamphlet. One of the funny things was the English in the pamphlet, which made no sense. It wasn’t anything important but a good laugh. The package comes with everything you need, the locking tools, allen key to adjust camber, 2 Rear adjustable struts, and 2 Front struts with pillow ball mount and camber plate. On to Installation, installation was a breeze just remove old struts slide out and reverse the process with new struts. A little tip to installing the rear, begin by inserting the bottom bolt then with the aide of a jack raise the hub and bolt into place. Once we had the struts installed we lowered the car and measured and adjusted the height to what I desired. I left everything the way it came from Megan. After install I saw noticeable difference in the way the car sat, it looked sick dropped about 2 inches. After we left the shop we decided to take the car for a test drive. With all Honesty my jaw dropped, we decided to take the car onto the highway, to my surprise every single problem I had relating to suspension was gone no more wheel hop, no more shaking at 55-60mph, no more weaving, the car felt solid and begging to be taken to its limit, so of course I couldn’t resist and had to take the car through some turns. I went to my usual turns in the city to see what my car was really made of and was blown away. There were twisties which recommended speed limit was 25 mph while I’m taking them at 83 mph and you can easily feel that you could push it even harder but didn’t b/c I was on stock tires and wheels, now I don’t suggest doing this on public streets. I’m able to achieve all this on the soft setting, imagine on the stiffer setting. I’ve had about a week of testing out the coil-overs throwing as much as I could at them and it laughs at me asking for more. I can truly say that just by this upgrade my car behaves like a new beast, even with my firing on 3 cylinder stock motor my car feels faster than ever before. I’m truly impressed with the quality, and performance of my coil-overs and would gladly recommend them to anyone looking for good priced high performing coil-vers. I must say Megan Racing received 2 thumbs up from me, keep up the good work. Hopefully this review will help others in deciding on which suspension to get all I know is I’m 100% satisfied and truly believe I got my money’s worth.
~Sincerely Puma King~
