Looks like its my turn to comment on my experience with Durdan Perfab.
First off, because I know he'll read this, damn it Taylor I was really hoping for stickers that say "We put the laughter in slaughter."
So, background on my harness. I've had my SR swap up and running for about a year now. At the time of performing the swap, I had contemplated sending it off to Wiring Specialties. What really turned me off from Wiring Specialties was the work of theirs I've seen in person for an RB swap. The harness wasn't clean, plugs were missing, and I constantly read about bad experiences others had had with them.
Wiring from S13 KA to S13 SR is simple enough, so I got the guides from both
http://www.frsport.com/SR20DET....html and
http://www.heavythrottle.com/. Both of these sites provide great data, allowing the wiring process to go quite smoothly.
Although my harness was in working order, there were a few things I wanted straightened out. First, I had never wired in a/c as I thought that I wasn't going to want it. WRONG! 100+ degree days here in Oklahoma suck. Second, when I originally extended my MAF wires I never used shielding. Shielding keeps electromagnetic interferences at a minimum, and is especially important for systems that require precise voltage readings (ie. MAF). Third, I wanted my Apex'i AVCR integrated into the harness. I can be pretty picky when it comes to my own car and feel that how your work is done is a reflection of yourself. Simply put, I wanted my harness to look a tad cleaner.
After seeing Justin's harness I knew Durdan would be able to redo my harness to my expectations. Turn around time was very quick and within 2 weeks I had my harness back, I think most of the time was spent waiting for my paypal to clear.
Here are some pics of my harness before:Notice the huge wire loom in the back? The igniter chip was just kind of hanging out near my strut tower. Also note I had extended my MAF wires to run over the fan shroud.
Here's my harness after getting it back from Taylor. The work is top notch.Hey look, no more wires running over the fan shroud. I have my pressure sensor for my AVCR mounted on my passenger side strut tower. Durdan did an awesome job integrating the AVCR harness into the factory harness.
Check out how much cleaner this now looks near the firewall! The excess is rewrapped inside the cabin, allowing the igniter chip to be placed behind the ECU. As mentioned before, the ECU can be accessed very easily, allowing it to sit almost in the passenger's seat. I imagine this makes access for ePROM tuning much easier.
Like Justin said, the pictures really don't do the harness justice. I highly recommend Durdan for anyone contemplating who to ship their harness off to.
Plus, he sends out stickers
