Revhard manifolds (formely known as "I searched!")
K240
Car: 1993 240sx
First of all, I searched, and I normally dont ask questions, I just read, but I couldnt find any info on this subject.
1. Revhard manifold. From what I understand, there is 2 different manifolds. One is flanged for both straight T4, and T3/T4, and one design that is just for T4. Is this true, and where can I buy a Revhard mani?
2. one more question- Ive heard of clearance problems (Brake master cylinder)-because of the On-center Turbines only. From what I think I have heard, I can fit a T3/T4 on a Revhard if I dont have ABS. IS this true?
Thanks for the help!!!
WDRacing
That sounds mostly sorrect, I know the T3 or T4 flange deal is right. But if you're using a T4, then you only want a T4 flange, the T3 is far to restrictive. What turbo ar you maybe going with.
Nice site by the way, I laughed my *** off at the pics and captions...well the cat ones anyway.
Craving4Boost
Car: 91 240sx fastback
even without the ABS the brake master cylinder would still be in the same place. you would still have clearence issues if you dont get a turbo with an on center turbine.
fyi...i have no ABS and a revhard and a tangential t3/t4. i had to hit the DP in about half an inch to let the hard brake line lean on it..(with heat wrap under)
WDRacing
T3/TO4's don't come on center...last I checked anyway. Only the full frame T4 does.
K240
Car: 1993 240sx
WDRacing wrote:That sounds mostly sorrect, I know the T3 or T4 flange deal is right. But if you're using a T4, then you only want a T4 flange, the T3 is far to restrictive. What turbo ar you maybe going with.
Well, im just looking at buying a Garett T3/T04E 50 trim, 63 A/R. So, in conclusion, there is no T3/T4 that comes in On-center, only tangential?
Craving4boost- So, is that the only mod that you had to do for everything to fit? What size Exhaust A/R are you running?
Also, where can I find a Revhard manifold for sale?
K240
Car: 1993 240sx
Bump!
Craving4Boost
k240, i have a .60/.63 AR t3/t4garret. yes that was the only mod i had to do. i took off the brake line that was blocking, knocked the DP in...and then put hte brake line back in. of course you have to rebleed your brakes since you took it off but its no big deal
K240
Car: 1993 240sx
Yeah, bleeding is cake, thanks for the help!
Does ANYONE know where to get a Revhard Manifold?
brunswick240
Car: 93 240sx SE
google revhard.com, or revhard turbo manifolds. I know they have a site, and a page on that site with a list of dealers. One of the dealers quoted me 280 + shipping on the revhard. But I had to call the dealer, they didnt have a site. Idk google revhard and try to find the main site and then find the dealers hope this helps, GL with the project.
