BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Mon Jun 04, 2007 11:30 am
A few "modifications" that can be reversed easily, provided you keep the factory parts;
Wheel/Tire swaps (Commonly known as RIMMMZZZZ) This modification, if done properly, will give the car that "I'm a drug dealer who spends his child support money on blingin' rims" look.
Cold air induction systems (CAI) which really don't do much of anything outside of bypassing the factory-installed Helmholtz resonator, making the car appear louder and giving the illusion of increased horsepower. Really, all these do is relocate the air intake to a (theoretically) lower point. Useless, but kick-@$$ looking.
Stereo systems; The factory stereo systems are great, but if you're looking to rattle the car apart, replacing it with a more powerful unit will do the trick. Many people make the mistake of chopping the factory harness off and splicing the wires directly to the replacement harness. Don't do this. Buy the installation kit, it'll save you time and hassle, and make the installation reversible in short-order.
If you decide to customize the interior by painting the plastics, be sure to obtain replacement parts first. I recommend trying to locate a Versa that was in a bad wreck and purchasing the parts you plan on painting, then swap them over once you finish painting. Use a paint designed for plastics and acrylics.
Custom-painted grille;This actually looks very good on some cars, especially the black ones. Reversible only if you have a replacement grille.
NAWSSSSNo.
Also, if you bought a CVT or even automatic, performance modifications will murder your transmission. Trade it in for a 6-speed. After-factory Transmission swaps are not really an option on these cars.
