Reversed terminals...need help
rockmafb06
Car: 240sx, 350z Nismo #24
First off I have a 91 hatchback with a redtop in it...So I was replacing my battery and like a jack a** I don't pay attention and put the terminals on reversed. I replaced the blown 75 amp fuse and the car will now turn over but won't fire. I can smell gas when it is turning over and it acts like it doesn't get spark. What else could have gotten cooked, I am thinking either the ECU or coil pack since there isn't spark. Would the coil pack even be a possibility or should I just worry about the ECU.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Find a friend with a similar car and start swapping parts back and forth until it works. Reversed polarity can cook a lot of things, although if you are getting fuel, your ecu probably made it through ok. I guess pull the cover off the ecu and see if anything looks burnt is a good start.
