Reverse Stuck
Stock-S13
My 89 fast back wont go into reverse anymore, this morning it was fine all good went in smotthly and every thing. but when i got out of school today i tried to put it in reverse and no go its like stuck. i tried really hard on pulling it in but it just won't budge.i dont think i did anything to provoke it i didn't mis shift or anything like that iam really despreate as this is my everyday car and my only form of transportation.any suggestions, and help are greatly appreciated.
Edgar
Stock-S13
i guess ill add this as well all the gears 1st to 5th work perfectly i redlined and no choke out or anything. could this possibly a throw out bearing problem? please iam here just refreshing any suggestions at all? could it be a shortage of trans fluid iam just throwing suggestions anything?
Edgar
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Just a suggestion, try rolling forward a foot or two and slipping it into reverse as the synchros line up. I find i have to do this a lot on my 13 year old transmission.
Stock-S13
thats what i tried on a hill in a parking lot on a hill but i tried this like 4 times and it just wouldnt budge. but thanks please people keep them coming.
Edgar
yellow_jacket
Car: 95 240sx
Can you get it in with the car shut off? What happens if you start it in reverse?
Stock-S13
oh i guess i wasn't clear before sorry, iam not able AT ALL to get the Shifter to go into reverse. :(My following attempts.
~ tried to shift into reverse when off : NO dice~ Tried to push it back from my parking spot about 5-6 feet and put it in 1st for about 3 feet and threw it in Reverse: No DICE~tried on a hill to roll forward, and then throw into reverse: No Dice~cant seem to get it to go in at all as if there was some kind of block or obstruction preventing me from getting into reverse.TIA
Edgar
yellow_jacket
Car: 95 240sx
Do 240's have a reverse lock out? I would check that. If it isn't that you will have to tear into the transmission.
Stock-S13
well ill im you but your not responding, what exactly will i need to replace if i were to tear the transmission apart? i was told shift linkage but the KA transmission doesnt treally have one, then i was told Fork but then since i can still shift through 1st to 5th i was told that wasn't either, so what exactly will i need to replace?oh yeah i was also told Reverse do not have syncros so there is no way those could be stripped.
Edgar
happyhourhero
maybe its the shifter itself.. somtimes, with t-birds atleast, the shifetr will break somewhere and 1 or more gears will seem like there is something blocking it, just a thought. and your right rev shares a sleeve with 5th gear, no seperate syncro
bmxruler4130
Car: a 91 se
i have the same EXACT problem with my 91. i took i to a shop and i was told the transmission had to be rebuilt :( it costs like 1200 bucks... or a transmission from the junk yard.if you find out any other info letme know.
yellow_jacket
Car: 95 240sx
You should be able to find a cheap transmission from someone who put an SR or RB in their vehicle.
91nis240
bmx ruler did you have them explain exactly why your transmission needed to be built or did you just agree to the 1200 dollar bill. If they did explain can you please tell us what happened
Stock-S13
Iam guessing his syncros are warped, kinda what iam thinking gappend to mine. today i was at a stop light and all gears got locked up for like 8 secs and i just drove ir back home. also i oulled the console and stuff around the shifter now iam down to the shifter itself, how would you know if you need new trans fluid? i also hear this like vacum noise i was like huh? so any help would be cool.
Edgar
bmxruler4130
Car: a 91 se
the shop told me it was average cost to rebuild was about 1200 depending, but that was an "average" price. he didnt know exactly what the prolbem was, and to find out the transmission had to be taken apart he said. but ive talked to some people and said it might be the slave cilender.
but anyway i didnt have the guy take it part because i didnt have them money .
yellow_jacket
Car: 95 240sx
Slave cylinder would affect all gears. If only one gear won't work it is some sort of internal problem.
Stock-S13
well all my gears are starting to go kind of a lock out thing. But i think a new transmission is order, becuase it feels slugish and i hear this sucking noise when clucth isn't in from the shifter. iam assuming thats that noise peopel are talking about when the pilot bushing goes out. anyone know how much a Throwout bearing and pilot bushing go around for at a dealership? But could this actually be a slave cylinder problem? also i hear a clicking noise from 1st-3rd.any input would be great seeing as how its about 2 weeks before i put in that 200k transmission in..
Edgar
djtodd
Sounds like the reverse gear assembly. I've never actually been inside a ka transmission so I couldn't speak with much wisdom on it though. :pface
nissanwalker
Stock S-13, Did you ever get this figured out, mine is doing the same thing! All forward gears work fine just won't go in reverse.
NISTECH
is your shift lever sloppy? has alot of play? if so pull the shifter out and see if the bottom of it is there. I posted exactly how to get the shifter out in another post let me see if i can find it.
NISTECH
here ya go and what do ya know the title of the thread is almost identical.
http://www.nissaninfiniticlub....ifter
NISTECH
http://www.nissaninfiniticlub....43407
