Salem240 wrote:Maybe this will help ya
http://www.ka24development.com....html
the reverse sensor and 5th sensor are both an open and closed circuit switch the reverse sensor actually has an OHM load that the ECM picks up on which will throw the CEL. You can do without the 5th, just not the neutral and of course the reverse and speed sensors.
Oh ok. So I have to wire the neutral sensor, just not the 5th? I was on zilvia and the post there said:
Quote »You do NOT use the 5speed lower harness, there's nothing to plug into on the chassis side for the wiring you're hoping to gain. Hardwire the reverse lights, run the wiring for the neutral and 5th position switches *if* you want the CEL to stay out. You do not need either one to operate the car.[/quote]Thus why I'm assuming I can do without the 5th position and neutral switches. I have the s14 speed sensor and the reverse-lamp switch so thats not a problem.
To be honest I don't really care if its throwing a CEL. I have a auto ECU so it will do that anyway. If anything I will just pull out the CEL bulb, but as long as the car is running properly I don't mind doing that. If I'm screwing it up by not using the switches then I'll go and buy them lol.
