Reverse lights ? WTF
Z32monster
Car: 1990 Nissan 300zx
Ok so my stock reverse lights were not working so i replace them with LED bulbs and they still wont work ???? is there a short somewhere ?
Sgt
Car: 1991 Fairlady Z (JDM) Twin Turbo
Firstly, check your fuses.
Secondly, the reverse sensor on the transmission may be loose, unpluged or broken. Take a look underneath the car and see.
dantesdoom
Car: 1991 Nissan 300zx N/A
1997 Nissan Pickup
Sgt wrote:Firstly, check your fuses.
great answers FTW
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
mine does not work eith and I had the transmission out and forgot to check them but I will test them this week.
z-goose
Car: 1990 nissan 300zx (NA, 5speed)
does anyone know how to change the reverse light switch on the trany?can it be done without having to remove or lower the trany
Sgt
It's just on the side of the transmission. You can get it with the car on jack stands.
Refer to this diagram to determine which one is the sensor ("Back-up lamp switch"): http://www.300zx-twinturbo.com/s.manual/mt/007.gif
romeoridgee
Car: 1993 Nissan 300zx 2+2 NA
does it have anything to do with the crusie control too? I took my car to a shop to get the sensor looked at because my reverse lights would flicker as i accelerate. i dont know what they did because my reverse lights dont even come on anymore, and my cruise control wont even turn on, like the light doesnt even come on when i push the on button..
ThisIsSparTTa
Car: 91 300ZX TT 2+0
Cruise Control can get disabled for other reasons too, like the ECU not getting a speed reading. Is your power steering working? Also pretty sure the cruise control also requires the neutral position sensor to be working. I'd read up the troubleshooting in the FSM.
MyZ32
Car: 1990 Nissan 300ZX NA
I am currently having the same issue, I noticed that the actual reverse light switch on the right side of the manual transmission breaks off and shorts itself out. That activates the reverse lights even though you may not be in reverse. I would look at that first. I have just replaced mine and now the lights will not come on at all. I am trying to find a further cause, I'm not sure if the stop and tail light switch may be faulty considering my Z shorted the other day and I no longer have tail lights either. The reverse lights were working after the Z shorted. I will try and figure it out, if anyone else has any ideas, please fill me in as well.
