KSee777 wrote:both the bulb and wires are fine... I just need to know how the reverse lights work..
The SWITCH in the transmission. Are you blind? The answer has been posted already. Do the same as topless recommended, but you can trip the reverse lights with the igniton on, the car doesn't need to be running. There are four switches on S14s, five on S13s, the wire colors for the reverse switch should be green and green/white. The green wire is the input, and comes off the gauge fuse in the car. In the future realize that some of us prefer for newcomers to actually USE their brain, no one is going to fix your problems for you. I myself have no respect for anyone who can't pick up a tool and at least try. You have the answer now, go fix it and let us know if it worked.
