Have someone put it in reverse and unplug the socket and check for voltage. If none there I would check the fuses. If not the fuse then you have some wiring to go through.EstoMax wrote:ok so after i got my tint i noticed that my reverse lights dont work. so i went and checked the bulbs. and their fine.
is there a common problem or anything to check for with the wiring or should i just get a voltmeter and start touchin things? also do they got a fuse?
max
