JonPowell »
https://forums.nicoclub.com/jonpowell-u5113.html
Thu Jul 08, 2004 10:36 am
The best thing, if you still can, is to use the KA lower harness, then all this mess is taken care of....
I am unsure of the wires for the RB harness as I use the KA lower...I would say, since you only have 2 sensors that are not the speed sensor, put the trans in neutral, send power to one side of the plug and see if you get power...if not, then put it in reverse and see if you get power that way...that is your reverse sensor, then hook those wires to grey plug...the green/white I know for sure feeds the reverse lights, the green/blue is the power to the reverse switch in the trans.
