reverse light assembly
petroskiw
Car: 2017 rogue sv
hi i need to know if anyone can help me find a video on how to replace reverse light assembly on my 2017 rogue. I know how to replace the bulbs but now need to replace the whole assembly because i chipped the housing. Any help would be appreciated.
Frzninvt
Car: 2021 AWD Rogue SL w/Premium Package
Champagne Silver
I would start by carefully removing the inside plastic panel to gain access to the screws or fasteners that hold it in place or better yet check you tube as someone has certainly had to remove them at some point.
Gone_Rogue_727
It's pretty simple... I did it a few times... remove the panel, remove the 3 nuts on each light that holds the tail light to the trunk door, and thats it.
Gone_Rogue_727
@petroskiw
Where are you located, if you are near NYC, and are interested in my 2015 Tail light assembly (which is the chrome outline ones), I am willing to do an even swap with you including the chipped one, all my tail lights are in perfect condition, my car just hit 5k miles, barely driven and garage kept.
Return to “Rogue Forum”
