Reverse is weak in g50
Cezar718
Car: 1995 Infiniti J30 (Rip)/1992 Infiniti Q45/1992 Nissan 240sx Convertible
well i just replaced my1992 q45 transmission with another 92 trans. with a 94 pump in it.... All the gears but reverse work... when put in reverse the engine doesnt even bog down like it should during a gear change.... hoping i wont have to rebuild considering the job costs $1500... any suggestions??
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Joe sells Nissan remanufactured for not much more after you return the core.
Why waste your time installing someone else's problem?
Cezar718
well its already installed and the head tech at my infiniti dealership is gona charge me an arm and leg to take the replace the transmission... is there no other way to see?
Cezar718
well i mean fix it?
Q45tech
What's an arm and leg ~~ $600 for a transmission swap is normal.
Never seen a decent local rebuild [ at least in dozens of ATL shops] always some minor problem and they never function exactly as brand new.
We love it when people come in with someone elses nightmare work.
One customer paid us to swap three transmissions before he would take our advice to buy oem Nissan rebuild.
NJ 666
Car: Couple SS's
It's possible the sealing rings slid out of their grooves in the pump. Since the reverse clutch is fed through the pump this might be possible. He should pull the trans and the pump and check them. It they are ok, then? Maybe a full rebuild if you plan on keeping the car.
Arm and a leg? How much did he want and what did it include?
Cezar718
o ok... lol do you have a charcoal gray g50 that you are working on right now?
