reverse indelgo guages install
DeeZNuTTss
Car: 240sx 4/1991 hatchback s13
:help i'm putting in my new indelgo guages and now i have to wire them the only problem is where do i hook the negitive and positive wires so they work correctly. i have a s13 91 240sx. thanx guys
DeeZNuTTss
i need to know where to put the positive wire thats all. someone please
BuudWeizErr
Just ground the negative to somewhere on the chassis, like under the steering column. There are all sorts of bolts you can pull out of there and ground out too.
Anand
Car: 95 Nissan 240SX
I tapped into my dimmer switch so the lights comes on when I turn the when I turn on the lights...
DeeZNuTTss
do i still but all wire to the back of the gauge houseing or do i just start aking out the bulbs from the back.
Anand
just leave all those lights in there.. I left mine and they are still on in the back of my guages.. can';t see them.. and they don't hurt them either...just tuck the wires into the bezel of the whole housing and it should be fine...
Just another 240
when you take out your cluster you'll see like a maze map behind it...and lil light bulb connect them..well tap into one of those line with the positive.
slw240sx
Car: 1990 Ca18det 240sx Hatch
any one recomend some good reverse indeglow gauge faces? i also need the KHM or will MPH ones also work?
stretch240sx
yeah im looking for new gauges if anyone could make some suggestion n where to get some that would be cool
