Reverse doesn't work, but you can still grab the gear
bigmuley
It's a 91 Pathfinder SE, automatic. You can shift into reverse and you can hear it engage, but it doesn't seem to have the pressure to go. Give it gas, and it just revs. Changed the ATF and filter. transmission runs better, but still no reverse. Any ideas would be great
88pathoffroad
Car: 1988 Nissan Pathfinder XE V6
Be prepared for a rebuild or replacement. Losing reverse is the first sign that the trans is about to die completely on you.
bigmuley
We did get around to doing a diagnostic on the transmission. Came back with LINE PRESSURE SOLENIODCould that cause reverse to not work?
