szh »
https://forums.nicoclub.com/szh-u149.html
Mon Jul 16, 2012 4:51 pm
Not exactly sure what to say here, unfortunately!
Does the screen look normal for all other non-video stuff? I.e., the GPS and vehicle operating information all shows normally?
Did this just start happening, or has it been this way since you bought the car (i.e., is it a recent used car purchase)?
Is it possible that somebody tried to do the "video hack" that allows DVD's to be played when the car is in motion (Eek!) and messed it up?
As a complete SWAG, I'd say the vertical scan of the video feed (i.e., from camera and player, etc.) is bad. This could be a broken wire in the cable/connector, or the video input line (meaning the line that does 0.75 Volt p-p video) on the LCD panel is bad. Could also be the video interface components/circuitry on the screen.
Try doing a reset of the car system (the Service Manual is at NICO - link is in my SIG below - may have instructions for this. You can also run extended diagnostics (also in the Manual) and see if it provides any insight.
If that does not work, search for a "24 Volt accessories" shop that knows what to look for with video equipment in cars, rather than taking it to the dealer.
Good luck with this - please let us know what the eventual fix turns out to be!
And, of course, welcome to NICO.
Z
