reverse and turn signal bulbs
tru3aznplayaz
Car: 1995 Infiniti J30
how do you replace them? i cant figure ou how to get to them
2brokey
Car: 1995 Infiniti Q45 - The Daily Beast
1994 Volvo 940 Turbo - Storage Unit?
1993 Nissan 240sx SE Fastback - Toy with big plans...
1992 BMW 325i Convertible - Needs to go to body shop...
Check this link out: http://www.fuzzycats.com/docs/tail_light_bulbs.pdf
This should be what you need.
naladude911
Car: 2001 Infiniti QX4
Front turn signals.Reach in the closest rectangular hole in front of car, between liscence plate and turn housing, and reach behind the signal housing. feel for the bulb, and unscrew. reverse lights, pry it out with a flat scrw driver, housing will pop out, and unscew bulb.
SilverJ30t93
Car: 1993 Infiniti J30t
Be very careful prying the reverse lense out with the flat screwdriver...I know this is the only way to do it, but suggest you wrap the screwdriver with a linen cloth before using it as a wedge. The bumper cover is soft in this area and the paint will be damaged easily if you aren't careful.
