revel s13 project
AZ89two4Tsx
Have you ever considered going pro? You do some VERY nice work and your car looks great.
Good luck on your build(s). Also, what made you get a hachi? I'm sure the power difference was a little bit of a change to say the least, lol
revel
Car: 91 S13
AZ89two4Tsx wrote:Have you ever considered going pro? You do some VERY nice work and your car looks great.
hoping to get the car straight (literally since the wreck kinda tweaked the frame a bit) and have it ready for full pro-am running next year. plan to go to a couple of the local pro-am events this year for the experience and to give me a good idea of what i need to work on for next year.
hachi vs s13 power difference is around 200whp...yea its worlds different. picked up the hachi for a couple reasons. always wanted one, so when i came across this super clean (for an 80s car its damn near mint) ae86 GTS coupe with the GZE swap it was really hard to pass up. drifting a low power (lucky if its hitting 150whp) car with a shorter wheel base is very very different from the 380whp s13 with a much longer wheelbase. everything about the two cars is different so by learning to drift a hachi properly i am hoping it will help me drift the s13 better. plus its a classic iconic japanese car..............and even with the GZE swap it gets great gas mileage (23-25mpg!!!).
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
YES
f*** YES
THANK YOU. I didn't know there was a build thread for this car!
I LOVE this car.
Keep it up, dude.
revel
Car: 91 S13
overs are now permanent........dont know why i ever messed with the flares now.......yes most every 240 has over fenders but man that make a car look good (as long as said car has the proper wheels.....which mine does....ego toot). the passenger side was a ton easier to bow out since it has the gas door to line everything up right...the driver side was a bit more complicated. would get a rivet or two down and then the body lines on the over would shift just enough to miss lining up properly on both sides. so the driver and passenger sides are a bowed a little differently. passenger side is great, but the driver side bows more at the back than the front and looks a little funny to me......but thankfully its just a drifter so i dont need perfection. its just going to hit things anyway so i am not stressin it like i would have before the big wreck or the wall kiss. also looks like i need to lower the rear a touch (although more on passenger side since the car is somewhat lopsided from typically only having a driver). front really needs lower...eventually will get around to it.
on to the pics;
troskinatior
Car: A Two Tone Piggy Coupe
Wow, the car is looking good!!!
Are you coming up for ECB?
revel
Car: 91 S13
troskinatior wrote:Wow, the car is looking good!!!
really really hoping to. do i need some kind of approval since its A and B only? wish i had a friend with a two car trailer and a truck to haul it, then split gas cost and make it a nice road trip..............................
troskinatior
You would most likely be in a B class but if you want to go into the A class and tandem then I think Petty has to watch and see if your good enough, which souldn't be a problem. I would PM Petty (sprinter666) on clubloose for more info. And make sure you can pass tech, I heard CL is one of the hardest to pass.
You have a full cage?
revel
Car: 91 S13
full cage with door bars.....dont think it would pass FD cage tech since the rear bars go down to a bar that connects the strut towers....seems FD wants the rear bars to mount to the wheel wells. after checking out the CL tech stuff i need a fire extinguisher and a cut off switch, but i think thats it.
troskinatior
That sucks about the cage.
If I get a helmet can I get a ride?
And I was wondering how much hp does this have?
revel
Car: 91 S13
not to worried about the cage......by the time i am FD approved i will probably be in another s13 shell......or something entirely different...or will have the cage meet whatever requirements are instated. as for hp..last time it was on a dyno it pulled about 380whp@19psi.
and yes you can.
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
Car looked better with rivet-on flares, IMO. Still f**king rad.
troskinatior
Woot woot!!! This is going to be awsome!!! Do you have a helmet? I might have one in time but I'm not sure.
revel
Car: 91 S13
HashiriyaS14 wrote:Car looked better with rivet-on flares, IMO. Still f**king rad.
thanks....i really did like the rivet on flares.....but it was time for a change. tried returning your pm but for some reason nico wouldnt let me so i sent ya an email.
troskinatior wrote:Woot woot!!! This is going to be awsome!!! Do you have a helmet? I might have one in time but I'm not sure.
still not sure i will be able to make it out..............if not this year definitely next year.
revel
Car: 91 S13
teaser:
TheBlaiant
Car: Slow40sx
troskinatior
I'm so actious!!!
And this is off topic but how do you become a member of drift mechaniks? Is it closed for a while?
revel
Car: 91 S13
troskinatior wrote:I'm so actious!!!
basically we kept getting bots sneaking in so andy shut down the register thing for a bit. should be back up at some point.
revel
Car: 91 S13
more pics once it gets a proper photoshoot
AZ89two4Tsx
:iconeek
costa_rican13
Car: 1993 s13 coupe
i can only dream of my coupe looking this good, being 18 and in college. but anyways! very nice wheel selection you have, and all exterior mods as well. excellent car you have. :)
troskinatior
hmm I don't know how I feel about it, I kinda like it unpainted better but your probably sick of it.
revel
Car: 91 S13
when i first put the red doors on it with everything else all mismatched i fell in love, but after seeing it everyday for almost a year it started to get a bit old and dated
revel
Car: 91 S13
240sxjoe92
Car: 1991 Nissan 240sx hatch
:drool: :greg: :chuckle: Its so clean. :woot:
some_white_guy
Car: '90 240sx white coupe
the kit and the color look very JDM but i love the wheels and the roof/decklid lips. how much did those two pieces cost you?
revel
Car: 91 S13
origin roof spoiler- around 250
dmax trunk spoiler- around 250
carbon-fiber-hoods
Car: Carbon Fiber hoods for Nissan S13, S14, S15
That really came together well.. Awesome color, matches your wheel collection nicely. Definitely one of my favourite S13's!
Cool blog btw.. I have to say your ride is "SIK!"
revel
Car: 91 S13
finally sitting proper
drove it around for a bit and everything clears pretty well. clears speed humps head on. fronts clear when the wheel is at full lock. pretty happy with it...........for now. might mess with front a little more
troskinatior
It needs to be lower, but other then that its perfict.
And also... forget road atlanta go to freedom moves, you can drive at road atlanta any day of the yeah
truckmtr240
Car: 91 240sx hatch
I wasn't really digging the beat to hell multi color scheme. then you hit me with that crazy shade of green that works sooooo well on the car!! Good stuff :dblthumb: :bigthumb:
