RevD!!!
JC87HB
Car: 1987 Nissan D21 HB
ok.. so i am requesting your help with the Center link... i cant get it off!!! tie rods came out with just a pull... all the nuts are off... it just wont budge... i tried 3 diff size pickle forks to no success =( help??
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
No pickle fork needed, take the nut off, turn the wheel, take a sledge hammer and give the arms a couple good whacks, it should come free. Pickle forks never worked for me.
JC87HB
i used a mallet... but.. it wont budge... am i hitting the arms or the center link???
Rev_D21
Since you aren't saving the centerlink I would give that a bunch of good whacks. It should fall right out. Hit it with some PB Blaster to help things along.
JC87HB
do they make a puller for such things???something like this?!?http://home.comcast.net/~alloy...d.jpg
Rev_D21
That could work, did you get the Harbor Freight link I posted in your other thread, that's the way to go if it's totally stuck.
JC87HB
im going to try the sledge today... im going to give it hell!! then ill order the puller haha
JC87HB
the sledge worked =)... just waiting on my parts now.. i need to get my pitman off too!
Rev_D21
I would use a pitman arm puller for that. Congrats on getting the CL loose.
JC87HB
pitman arm puller sounds grand!
