89240sxdude »
https://forums.nicoclub.com/89240sxdude-u11127.html
Tue May 11, 2004 6:14 pm
are u sure u checked the codes correctly it goes liek this. key on, dial on, the leds will blink twice then three times and shut the dial off then it will show the code. if theres nothing wrong both will flash 5 times. if there is a code take note of it and respont on this tread and ill tell u what it is and to erase the code after this < u start the car then turn the dial on 2 seconds, dial off, car off, car on and the code will be erased
