Rev Problem??????
Sleeper415
Car: 240sx
ok im have a really big problem with my reving its like my fule cuts ok every once in a wile like a around 2 grand if i try to hold it at 2 grand it cuts off and then shoots down to like 1500 then shoots back up to like 2200-2300 thats if i hold the gas in one spot if i give it any more it revs up higher i just cant give it gas slow????
hpmachine
Car: '05 EVO8 + '95 240sx
maybe it's because your ecu is being thrown into saftey mode. there are multiple reasons for this happening (temp sensor, maf, o2 sensor etc.) basically it's a saftey catch so the ecu wont let you rev the engine over 2500 rpm if it's not getting all the right signals.
S13FASTBACKSR
Car: '92 Fastback SR powered
I think it struggles to hold voltage somewhere along the lines of your engine such as tps or maf if you try reving slow..reving fast somewhat forces it to keep going because you are quickly raising the voltage..are you getting in misfiring around the lower rpm band when reving it? i say check your tps voltage..should be .45v to .55v at idle and 4.5volts at w.o.t. also check your maf voltage...look for a 12v reading from one wire and a 5v from the other the last wire is a ground..also check your ecu to make sure its not bad by looking at the l.e.d. on the back of it while the engine is running..if the l.e.d. is on with the engine running then the ecu is bad
Sleeper415
Car: 240sx
L.E.D. lights off and i also checked for leaks and everything good there is won thing i unpluged my TPS and it lets me rev nice slow fast dont matter so i think its my TPS but im not sure please let me know if im right or wrong????
cuz im not a pro i just do dumb things some work and some dont. thankx for the answers.
S13FASTBACKSR
Sleeper415 wrote:cuz im not a pro i just do dumb things some work and some dont.
lol anyways bro do you have a voltmeter? if you do you can check the voltage of your tps while its idling and at w.o.t. and you will be able to tell if its bad or not before you buy a new one...the wire all the way on left should be the power i think...when your car is idling it should be .45volts or so no less..and no more than .55volts ...then the lever on the tps you push up and it opens it a.k.a. w.o.t. and it should read 4.5volts all the way open
