spec-u-later wrote:Flames aren't that bad. They only occur in last foot or so of the pipe. The old guys used to drill a hole in the exhaust pipe and stick in a spark plug. They would then hook it up to a current they can control. Since they didn't have cats there would still be a lot fumes in the exhaust. They would just flip it on an boom, nice flames shooting out the pipe. I think this is only cool on old muscle cars and would not suggest doing it. Plus you might melt your bumper.
k6kicker wrote:well if its ka powered you wont ahve any will/need to rev that high![]()
Toad[^_^] wrote:I was looking at the RB25 limiter at Bee-r Racing
Thanks:ylsuper
NeverEnuff wrote:dont 240s alredy have rev limiters?
JustinStrife wrote:I don't see much point to doing it except for rice...
Nismo_Freak wrote:240s have rev limiters dude... I used to hit mine occassionally.
It's around 7000 rpms I believe, or at least mine was.
There is a very very valid reason for having a rev limiter w/ launch control... consistancy. That and your launching under WOT. Launching under WOT in a turbocharged car can actually build boost pressure at the line and at least cut down on the spool time.
spec-u-later wrote:Ok are you talking about launch control. I think I was asleep for the first half of the thread. I have a friend that has it on his wrx and it rocks. You set it at say 5500rpm (wrx) for the launch. You just mash the gas at the line and it stays at 5500. When you put it in gear an let go of the clutch you launch. Then you have an alternate setting for each shift. You just keep it floored the whole run and it will stay at whatever rpm you set for in between each shift.Oh yeah supafly already said this btw.
JustinStrife wrote:I was referring to the part about shooting flames through the exhaust... Not the rev limiter itself.
