Rev Limiter?
RS12Turbo
Does the ca-det have a rev limiter? Out screwing around........ my engine cut off right about 7k rpms @ wot in 5th gear.
Modified by RS12Turbo at 12:55 AM 11/9/2007
RS12Turbo
Hmmmm, no response I hear these engines have a speed sensor, but I am using the S12 transmission with the s12 mech. speedo cable....so I don't think it would be that.Boost cut? Rev Limit?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Yeah, I forget where the stock rev limiter is. I thought it was 7500, but it could be seven. In any rate its gloriously low so you can bounce off it all week at autocrosses and whatnot.
RS12Turbo
Cool.....I think it was higher, probably 7200ish.......I was going off of my factory tach, which is a about 200 rpms or so less than what my s-afc2 says.
r34 gtr
7200 sounds right to me. Did it cut off completely or just do the rev limit deal?
The tach signal from the stock ecu blows. My EDIS system has my factory tach deadly accurate and I love every minute of it. Come to think of it, I'm gonna go tune the bastard for some more timing and this gloriously low ambient temperature.
RS12Turbo
r34 gtr wrote:7200 sounds right to me. Did it cut off completely or just do the rev limit deal?
I dunno, kinda scared me.....I let off right after, and exited. Engine never actually shut off.....felt like the speed limiter in my maxima.....kinda shuts down for a sec.
r34 gtr
dumb fuel cut terrible limiter thingy.
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
is it only in fifth gear or something? I managed to hit 8500 once in my pulsar (maybe why my bearings copped out) and I never got hit by a limiter?
bentvalves
Car: 89 Silvia K's
5th gear WOT would be a fuel cut....how fast were you going?
did it sound and feel gross?
float_6969
Did you look at the boost gauge? That much load on the motor could have caused some boost creep with the turbo and you might have the MAFS cut.
RS12Turbo
ks13 wrote:5th gear WOT would be a fuel cut....how fast were you going?
It felt like it hit a wall......as soon as it happened I let off, and everything was fine. I don't know how fast I was......my speedo tops out at 125 .I didn't get a chance to look at the boost gauge.....but recently with the cold weather I have noticed some creep.....16psi or so. I need to turn it down a notch I guess for winter and get a real boost controller
Liquid_Neon
holy poop, I just realized how fast 7000 is for my car. FWD ca have 4.441 final drive, so at 5K I'm doing 100mph and 6K is 120 and I ASSUME 7K is 140mph.... so um, yeah. Thats fast without a doubt.
RS12Turbo
Liquid_Neon wrote:holy poop, I just realized how fast 7000 is for my car. FWD ca have 4.441 final drive, so at 5K I'm doing 100mph and 6K is 120 and I ASSUME 7K is 140mph.... so um, yeah. Thats fast without a doubt.
Mine has a 4.11 r200......I was actually screwing with a Integra type r turbo late nigt on the interstate.. We pulled over and chatted......he said I was doing 145 when I passed him
