Rev limiter
mexicana
Car: 1991 D21 Hradbody
Does anyone now how to bypass the rev limmiter on a 91 hardbody with a ka24e??
neverlift
chip the ecu or buy a rev limiter like the bee r.
mexicana
can i chip the ecu without buying enything and bee r?
neverlift
no your gonna need ATLEAST a socket and chip,also a burner.or you can buy a chip from someone and get the socket yorself, but then your stuck with that tune if you boost....
mexicana
could i bypass the limiter with like a msd 6a ignition box? and there's no other way to by pass it with out a lot of money dropped into it? Is it possible to mod ecu like in hondas?
neverlift
yeah a 6al will do it with a tach signal converter, and thats gonna be about 300 with all you need for install. I've had an msd before not worth it IMHO coil wiring mod does just as much...
now yes you can mod your stock ecu IIRC hybridka has some adr/bin that will let you run it off a stanza ecu. Dont hold me to it though. I dont know ****.
