Rev Limiter
SR20Drif
Car: 1992 Nissan 240sx
Ok, i have a 92 240sx with an SR motor swap. The shop that did the swap told me that the SR setup doesnt have a rev limiter. If so, then how do i get a rev limiter??
vlow1210
maybe your ecu is programmed and has the rev limiter removed.
wanna trade ecu's for a stock one ?
terribleto4e
Car: 1992 q45, 1991 fully built mr2 drag car
When i got my sr swapped 240 they had the harness running through the fender and the tire had hit the harness and tore like 5 wires off...the car ran and drove but had no revlimit, i could maxx out my speedo in 3rd gear going to 8500rpms, now i fixed all those wires and have a limit of 7500
so trace the harness diagrams and you can find a wire to disconnect which will allow you no revlimit
david
SR20Drif
I beleive my ECU isnt programed but not too sure. I traced the wires and all my wires were connected. Im gunna have to go back to the shop and find out wuts up from them. Thanks anyways guys
