p00t wrote:rev limiter is set at 6800 in gears less than 4 and in nuetral.
in gear 4 and 5 the limiter kicks in around 5000. They did this to limit your top speed to around 120.
THIS IS NORMAL.
there are ways to trick it by cutting wires and such, but u might lose your speedometer. the only way to fix it that i recommend is a reprogrammed ECU or one of those little computers that u hook up between the ecu and the sensors that tricks your ecu into thinking its at a diff rpm.
The revlimiter is always the same place. There is a speed limiter. That is why the car shuts down at those speeds. It has nothing to do with where the tach is, it's where the speedo is. I know it's technical, and theoretically the same concept, but just realize that the ECU is watching speed *and* rpm, not just rpm.
