justin240 »
https://forums.nicoclub.com/justin240-u123144.html
Mon Dec 29, 2008 2:50 pm
i know the MAF is good but i dont know about the ECU, i have only changed the spark plugs and wires, the cap and rotar, and put on a cone air filter, i have also added a few electrical things but i always run all of my accessories directly off of my battery
i never had a problem with it untill i buried my tach when i hit 115 and buried the tach it did the cut out and i figured it was a speed limiter or rev limiter so i didnt investigate it, i did alot of in town driving after that so it didnt happen again until i took it on the freeway and it did it at 85, i was kinda lost at this point, but recently i have started to play with the "limiter" and it always happens at 85 in 5th like its set, so i took it to 85 and as soon as it cut out i put in the cluch, let it drop bellow 3k RPMS and let the cluch out and layed on the gas, i made it to about 100 before it cut out again, so its definatly not a set control but i cant think of what kind of short, or lelectrical problem could possibly cause it. i can keep it from cutting out if i am very gentle on the gas and gradually accelerate past it but i still dont make it past 90, also it doesnt like hills, i cant do more than 75 on hills before it cuts i think it has to be related more to speed than RPMs becasue i recently took my car out for a little fun in the snow and it will rev past 4k and 5k RPMs in 5th over and over again with no problem, im pretty much stumped.
