rev limiter has mind of it's own
eastcoastchaos
Car: 95 240sx
my rev limiter now hits at like 5500rpm's when it shouldn't be till at least 7200. i just had the transmission re-built and about a week later i finally gave her hell. to my surprise i can no longer play in the upper rpm range. i asked the transmission guy about it, he said it might be a fluid level problem. idk. if you have any ideas please feel free to share them with me. thanks
MyCarIsWack
Car: stuff
remove ur 5th gear sensor, its prolly burnt out
but it will fix it ASAP
eastcoastchaos
Car: 95 240sx
but it does it in every gear. and only since i got it back from aamco
MyCarIsWack
Car: stuff
i know, its ur 5th gear sensor, just unplug it
trust mei had the same problem
eastcoastchaos
Car: 95 240sx
i'll try but, why didn't it do this before the transmission fixen.
MyCarIsWack
Car: stuff
mechanic could of ****ed it upor it just could have been coincidenceits no big dealsame thing happened when i got my clutch done
eastcoastchaos
Car: 95 240sx
aight thanks. will i be loosing anything from this, like no tach in 5th or my speedo bein gay? thanks again
MyCarIsWack
Car: stuff
no everything else works fine
SilviaS14KA24DE
Car: Doriftu
so, whats the verdict? did it work eastcoastchaos?
eastcoastchaos
Car: 95 240sx
um, i've been too busy but i'll try tonight
Newcastle82
Car: sold my s13, have no car.
Hey, on this topic that I've been silently following..
I'm not having any problems with revving, but I wanna yank that rev limiter anyway. How do I do it?
Is it one of the wires coming out of the transmission, just behind the clutch slave cylinder? If so, which one?
Thanks.
MyCarIsWack
Car: stuff
1 believe there in order1 being closest to the cylinder5th being furthest5th is the 5th gear sens, i belive 4th also does speed, so u wont have a speed goven
Newcastle82
And to remove those sensors, what do you do?
Cut the wires? Or is there a less janky way to do it?
