stock cams for now...the original owners motor blew a ringland and this one was rebuilt. I guess it did some damage so he overbored it a bit. lol I'm assuming i'm about 2.7L or so...I dont know how much i'd pick up from the bore I'll bump my revlimiter to 7400 and go from there...that will help a little i guess hahaCjmartz2k wrote:I'm a Mustang guy, just wanted to get that out there ;-)
I've got money it's your tune. You should have walked him. Revving higher it with a P&P head and a T70 will help. What cams? If stock, I'd shift around 7.5-7.8k.
That's a pretty big overbore on those pistons mang
VVT are referenced on Toyota engines.lilskyline240 wrote:how do you go about disconnecting the VVT? is there a wire for it?
i know on other motors when you start reving super high, they can strech rods pretty easily. I didnt know if there was a problem on the bottom end of reving high, or if it was just the valvetrain. And I guess the crank snout.BoostFab wrote:and again, your rod don't stretch. not sure where you get that idea. they either bent or snap due to dentation.
no! your rod don't stretch. it's the rod caps bolt that become the weak point when reving too high, that's why i suggest upgrading to ARP rod cap studs if still running on stock rods after certain power level. When the weak cap-bolt fail (stretches), causing the bearing to lose clearance at the narrow point, leading to bearing seizure and the rod grenade out your block.Largekid wrote:i know on other motors when you start reving super high, they can strech rods pretty easily. I didnt know if there was a problem on the bottom end of reving high, or if it was just the valvetrain. And I guess the crank snout.
thats good to know w/ the overbore...thanks!WhatsADSM wrote:Hate to say it but honestly considering the rest of the setup that turbo is too big. Have you ever considered getting a smaller turbo and moving the start of the power band down instead of trying to rev it more.
IMO honestly your car would be faster with a smaller turbo as is. A 35r would be a MUCH better fit.
**Edit** Also a .080 overbore on a rb25 is a ~2.62L
