Spins »
https://forums.nicoclub.com/spins-u7278.html
Wed Feb 23, 2005 9:10 pm
I have a 95 sr20det blktop with automatic transmission. I started having a problem in first gear. If I roll on the gas my tires break loose and start spinning . Well this is fun an all but my car revs so quickly with the tires spinning that the auto transmission cant keep up. The engine revs to around 7100-7200 and the misses once before the transmission shifts. Kinda sux. Do you manual guys have this problem. I mean if my auto spins the tires. You manual guys must bounce off the rev limiter all the time. I'm not even at WOT and I have this problem. I don't know for sure if it's the limiter i'm hitting or a high rpm miss. If I don't spin the tires the transmission will shift out of first gear around 6800rpm. I'm running my sparkplug gap around .025. Is the rev limiter on the sr's 7200rpm?
