rev hard mani ?
Artaxerxes
I was wondering if anyone could tell me for certain weather or not I should cut between the runners on my revhard flange? Also wasn't it intended to be a top mount ? The reason I ask is because I read on this forum that it needs port work to be used that way.
Structure240sx
yes definitly cut the flanges. it is suppose to be a top mount manifold. it doesnt NEED to be ported jsut like it doesnt need to have the flanges cut. its jstu a good idea. i jsut opened up all the ports enough to match up with the exhuast manifold gaskets. i havent had any problems with it yet its been 4kmi
TrunkMonkey
Car: 2000 Lincoln Navigator
isn't the current run a revised version? iirc, the original manifold was a bottom mount and porting was necessary to get everything to line up...either that or i'm sniffing too much of this carpet fresh.
-demetrius
C-Kwik
I got my new rev-hard less than a year ago. The ports don't line up. As far a I can tell, the reason it doesn't is for two reasons. I think they assumed the KA ports were centered between each set of exhaust manifold studs on the head. Secondly, the ports on the Rev-Hard mani are round. The KA ports are square. Cutting the flanges is an extremely good idea. The mani-to-head flange is rather thick and will not heat up as fast as the runners which will cause the runners to want to expand more than the flange. Either from too much heat or repeated expansion and contraction it may form a crack, most likely in the collector area. Another good idea is to take a dremel or grinding bit with a drill and remove and cast flashings. These shap corners tend to be where cracks start. And anything to minimize cracking is a good idea on any manifold.
Artaxerxes
Thanks for the help guys. Just one more question. My manifold only has holes taped for a t4 does anyone know what spec bolts I sould use?
Structure240sx
i think it was c-kwik that said stock exhuast manifold studs and nuts fit and work great, wont get lose. i think i might try that when i get my turbo back
Nathan
Or, get some really good Grade 8 bolts (3/8 in. I think off the top of my head) with some split lock washers and tighten them WAY down. I can't possibly see how Grade 8 bolts with lock washers torqued to ~70 or more ft. lbs could come loose.
C-Kwik
You need to make sure the studs are torqued down using the double jam nut method. It will hold fine. Stock manifold nuts work great since they are mechanical lock nuts. Spring/split lock washers are a joke with turbos. The heat basically turns them into flat washers. If you want to use a lock washer, you need to use serrated washers. But I've tried it and they have come loose too.
Structure240sx
whats the double jam nut method? using two nuts on one bolt?
C-Kwik
yep
