reusing valve seats
sleepyS13
I am replacing the head now and want to port it and touch up any flaws. My question is when i disassemble the head can i put the valves back in the same location with out new seats and machine work, the head is off a car that ranwith good compression but started leaking between oil and coolant passages after over heating.
how far can i safely shave the head
is it a stupid idea to grind the casting seams off of the rocker arms
:thinker any input is appreciated
Und3rprshUr
Car: My 300Z
The valves do not have to be in the same location. but make sure you have a machine shop do a valve job for you.
Why are you shaving the head ? you think there is benefits to shaving ?
Grind away on the rocker arms.
sleepyS13
yes wont it increase comp. ratio a little?
i thought that was a given- am i missing some thing?thanks for your response.
Und3rprshUr
Car: My 300Z
You would have to shave a nice chunk out to make any diff. and then you would have other problems.. its not worth the effort time and money.
