CleanSfourteen wrote:Considering the fact that most of the bottom-end components in a KA24DE are good to withstand as much as 350hp, i would suggest working with what you have. The crankshaft is forged, internally balanced and known to be 'indestructable' and the rods are also quite durable.
I think you need to base your decision on what you're going to be doing to the engine. Daily driver?? re-use the rods and crank... Dyno queen?? time to start going aftermarket...
However, KA's in some areas are so common that you can easily find one for pennies on the dollar. I don't live in florida, so i havent that option. When i build up my KA i am planning on leaving the engine alone besides headwork and possibly pistons. I figure as long as i dont go all Inital-D on it i should be okay.. hahaha
I would encourage you to be more weary of parts that you have not seen in operation/have no story to.
took me a while to get to a computer again, but I did it. I wasn't aiming for a dyno queen or a daily driver. D/D is a stock Civic, this was going to be a toy and a spare for when the Civic breaks. Thinking seriously about FI, if not, then high compression.
Under the token of being wary of parts I have no story on, the entire car is that way. I got it in non-running condition, and everything I see indicates to me that it's a ragged out piece of junk. I've been putting feelers out for engines around in my area, I just haven't had a lot of luck finding one for a good price.
The problem with my crank isn't that it's stock, it's that it spun a rod bearing and was badly grooved and worn. Ditto for the rod.
Can anyone tell me if the crank/rod from a FWD KA24DE will work, or if the crank/rod from a KA24E will work?
I have a guy that offered to sell me a complete KA24E... could I just swap the heads out?
Thanks for the info, everyone.
