reuse piston rings after only 500 miles?
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
hey guys, so my fully built ka with honed 89.5mm cylinders and pistons spun all mains after 500 miles.. long story not gonna go into it. Anyways i have my spare block at the machineshop now and im gonna transfer everything over. The pistons i have are the wiseco 89.5mm's and their piston rings, so the question is, do I need to order new piston rings (and where!?) after 500 miles? Or if i have fresh cylinders then those piston rings will seat fine in those too
Thanks for inputMarko
Florida240sx
Have hmm check clearances.... But the might already be broke in and wor... wait for WD, Ivan,fanatic etc. to chime in
scarboroughdub
what if it doesnt seal properly then what, im pretty sure your not gonna want to remove your head and oil pan to redo the hone and install new rings.
get new rings, wiseco can send you new rings or im pretty sure you can match aftermarket ones.
radek
Emc-Icon
Car: 1990 240sx (in the middle of ka24det swap)
better safe than sorry, spend the money now instead of time/money/labor later..
WDRacing
Huh, I dunno how I didn't see this thread floating in here...
Honestly, you could go either way here, I've taken the rod/piston/ring combo out of an old motor and installed it into mine on several occasion. This was on an RB20, but the concept is the same. This was on a stock motor. I knew it would be raced and I knew I'd pop more pistons, so I didn't really care. It did work well however.
But on a built motor, I'd get new rings. Start fresh, hopefully this time you'll remember to keep enough oil in it...lol.
bruinbear714
EstoMax wrote:hey guys, so my fully built ka with honed 89.5mm cylinders and pistons spun all mains after 500 miles.. long story not gonna go into it. Anyways i have my spare block at the machineshop now and im gonna transfer everything over. The pistons i have are the wiseco 89.5mm's and their piston rings, so the question is, do I need to order new piston rings (and where!?) after 500 miles? Or if i have fresh cylinders then those piston rings will seat fine in those too
I would replace them, especially if the pistons are getting moved over to another block. The honing of the block + new piston rings allows them to seat properly to provide good compression.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
ok so the question is where do i get wiseco piston rings? i've been looking for them and i cant find any place that sells them really for my piston application.. do i call up wiseco directly ??
thanksMarko
WDRacing
Yes.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
update found out importperformanceparts.net has piston rings for the wiseco's seperately too.
