TLeid wrote:Alright thanks guys. Put the OEM ones in and all torqued down fine. Guess we'll find out if it leaks.
Thanks for the advice!
You're more likely to leak with the Cometic and ARP's than to stretch reused OEM ones and leak =( The Cometic wont smoosh like OEM to fill any imperfections on the head..and the ARP's dont get torqued to hell to pull it tight enough (if there are imperfections). I would use either/or personally.........cometic w/oem bolts if you had the block decked........ARP's w/OEM HG if you did not.
Modified by mbmbmb23 at 12:37 AM 10/12/2009
