Fearspect »
https://forums.nicoclub.com/fearspect-u209440.html
Tue Mar 12, 2013 3:02 pm
Talked to Greg at SpecialtyZ, here is his response:
"We can perform the tune with a stick program and we can manually lock the converter, so we can make a good tune and it will still work while it is automatic.
The power will show lower as the automatic pump inside the trans robs additional power to run the pump."
Just wanted to share it if someone pulls up this topic in the future. In short, it seems like if they didn't have this 'stick program' the tune would have to be redone. Just your numbers on the little dyno sheet will come out a little lower than they otherwise would, and performing the swap will up your hp numbers.
