Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Wed Jul 25, 2012 11:19 pm
It's theoretically possible to retrofit side airbag modules into a side airbag-less Pathfinder. One would need to replace the main airbag control/diagnostic unit located under the center console, add the side airbag sensors in the pillar trim area below the front seat belts, and obviously the side airbag modules themselves (including harnesses). Perhaps all of this could be found at a junkyard.
What I'd be concerned about is whether the seats are compatible - in other words, do they have the correct area to bolt the airbag modules into. Everything else should be good; the airbag "brain" just swaps over, and the side airbag sensors should just bolt in place.
Has anybody ever attempted such a project?
