DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri May 27, 2005 3:39 pm
Replacing the drier is a must for longevity, but it won't do a thing for cooling. Make sure to blow/flush out any dirt and debris around the condenser and radiator.
The AC is a heat pump system, so you would probably have to upgrade everything for an appreciable improvemenet. Bigger compressor to pump more fluid, bigger condenser to cool more fluid, and a new evaporator to flow more fluid. Can't tell you what the weakest link in the chain is right now, but it could easily be that something is not performing as well as it could. If the line leaving the condenser is hot then a second fan might help if you can figure out where to put it and how best to wire it in. Consider loads, wire ratings, and the impact to the alternator's and/or battery's life.
Did you get a rebuilt variable displacement OEM compressor designed for R134a installed? How about the hoses, did they replace those too?
