UndeGuy »
https://forums.nicoclub.com/undeguy-u136480.html
Wed Jan 13, 2010 7:40 pm
That is a dual bulb system... so you have four wires, two for each bulb. On low beam, power goes to one bulb. On high, power goes to the other bulb.
You most likely have an H4/9003/HB2... or simply single bulb system, you'll need and adapter. From three to four. In an single bulb system, it has a common wire.
I would recommend getting an adapter... check your ebay again.
If you have to do the cutting, then find out if two of those wires are connected to each other, one from the ballast, and one from the other pair. That will be the common wire. Then you just need to make sure you get connection to your wiring correct.
Just for reference, the headlight socket for the pathfinder melted so I had to put a new one in. I mistakenly swapped the common wire with the other wire for high beam. You know what that did?
My high beam worked, because it's not polarized, meaning power still went through the filament. In one side, out the other.
But my low beam... didn't work the way it should. Because now, it's getting power from BOTH ends... and no where to go. Because power has to go SOMEWHERE, it actually forced it down through the "low" end, which actually lowered the amount of power I got to the bulb, preventing it from lighting all the way.
Once I swapped the offending wires, it worked correctly.
Another, similar story... When I had a Mitsubishi Mirage, I swapped the headlight housing out... I also went from the stock single bulb to dual bulb set up. Luckily for me, the housing came with a wiring harness... unluckily for me, it was backwards. Low beams came on with the lights set to high, and vice versa. So I had to pull the wires in the plug and swap them.
So, that's a possibility for you too when you start cutting wires together..
