After a few days of research on Retrofitting TSX/s2000 projectors onto my s14 headlights(zenki), I couldn't find an exact solution. My problem is that i will be getting tsx projectors in a few weeks and is wanting to know if i can take the more simple route. This simple route is instead of building a custom hid kit(piece together factory ballast,igniter,bulb), wouldn't it be much easier to buy+install an aftermarket HID conversion kit. Would this type of build(tsx ballast +a good set of aftermarket HID Conversion kit) give me the same OEM HID quality? As you could tell, i'm a novice with lights...oh ya could someone tell me if i'm getting the right parts?
If taking the custom route:1)TSX projectors2)ballast D2S/D2R + igniter, D2S bulbs
If taking the easy route:1) TSX projectors2)HID conversion kit D2S/D2R
SPECIAL CASE: Would a 2003 Maxima OEM HID kit be able to retrofit into the TSX projectors?FYI--> maxima bulbs are D2R
Hope i can get some quick replies, I thank you in advance
Here some research i did, but not specific enough...like the relay part numberhttp://
www.phihoang.com/s14hid.htm
Modified by zenkii at 11:59 PM 12/4/2007
