nukeone »
https://forums.nicoclub.com/nukeone-u31978.html
Sun Jul 02, 2006 3:37 pm
I have A/C in my '92 vert. Used the RB20 compressor and the KA discharge (small) line, but had to carefully bend the hard line to get it in the right position to re-connect to the condenser. I used about a foot of the RB suction side piping and had a connector made to reconnect to the KA suction side piping. Cost me less than $60 for a hydraulics shop to make the compression fit style connector that you can see in the photo. The connector is in the center, directly beneath the blue silicone lines to/from my boost controller solenoid. I have used these style connectors for both SR and RB A/C lines and never had a problem or a leak. I also converted to R134A so I added the R134A fittings. I wired mine using the KA compressor signal wire and didn't worry about the RB compressor pressure switch wiring, since the KA dual pressure switch remains functional to kill the compressor on 1) high pressure, or 2) low pressure (loss of freon/oil).
