Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Mar 04, 2009 5:40 am
I've never had a problem resurfacing SR flywheels.
However, since you mention it's a lightweight flywheel, I have to ask what type of flywheel is it? A chromoly or a fidanza style with the replaceable steel rings? If it's chromoly, or some other type of lighter, harder steel, you will want to tell your shop. A lot of shops will refuse to work on or charge you more for those types of flywheels due to the amount of wear it puts on the machining bits. If it's a fidanza style, you'll need to order new steel insert rings and have them installed.
