deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Mon Nov 07, 2005 9:26 pm
I havent been able to find the formula that the ecu uses after it has calculated a tp, to where final injection pulsewidth is calculated. This would help with full insight on all of the factors.
Acceleration enrichment is an obvious addition if the ecu senses enough tps v/s. It will jump to that routine and add pulsewidth, either by a certain amount of engine cycles or a pre set time. The accel_enrich settings in the rom have something to do with this, they seem to be mapped to a range of TP? These values may be the amount of additional injection, or the engine cycles/time that the enrichment is applied at that TP level?
What im getting at is that perhaps that duration of 14-13.5:1 in your log is also a duration of accel enrichment (of which would be just a tad bit lean).
I have experienced very long durations of accel enrichment needed, very similar to the amount of time before your log drops closer to 12 (accel enrich no longer needed, engine fueling needs stable).
That is with my standalone and ITB anyways.
Btw, I run my wideband in a "test pipe", cat location. Works excellent.
EDIT: Or, it appears as if the accel enrichment may be triggered twice on your run. The lean areas being the ecu jumping back to only the map value. In this case, without good control of the accel enrichment in ecu (needs to be figured out) you would have to richen the points of the map that it is hitting on that wot run.
