NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Apr 11, 2005 6:53 pm
did you plug everything back in form the inside of the tank?A quick circuit check you can do before pulling it out of the tank is unplu the 3 wire connector on top of the unit ,find the green wire in that connector and ground it to the body. turn your key on and the fuel gauge should go to full. if it does then you have isloated the problem to something in the tank either its unpluged inside or it is damaged. or you simply got the float caught under something. if when you ground the wire the gauge does NOT go to full then you have a wiring or gauge issue. I suspect its in the tank though and likely something you did since its not working after you did it.
