elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Jan 26, 2005 11:18 am
Indeed.. No offense to her, but she has made the "Q45 repairs for dummies" writeups on many things... not to insult her intelligence, but to show that her writeups are very thorough..
If you can dodge a wrench, you can dodge a ball... wait, if you can turn a wrench, with tangalora's writeups, you can fix a Q45
Like I said, unless the pump is failing (car would be hard to start, and it would "chug", but be "normal" on WOT), then thats the case...
Another thing to check is timing... After I replaced my KS, my timing was still off about 5-6 degrees.. I had done about everything i could that would affect performance, and the timing was still off... I attribute 125-130k worth of chain stretching to throw it off.. The car was "normal" (sans sludge) in every other aspect, plus im certain that the CAS wasnt messed with... I seem to recall some paint marks, to show it wasnt messed with.....
on Q45.org, we have about 3-4 writeups on fuel pump replacement......
