redmanfx »
https://forums.nicoclub.com/redmanfx-u15036.html
Sat Sep 16, 2006 10:21 am
Sandblasting can be done, but you will get an etched surface, so you'll have to wet sand it down to smooth it out. Restoring them will take more time since they are wirery or "spoked" in nature. I would try to find someone to glass blast these instead of sand blasting them so you get a less etched surface. Heck that might just do it for you anyway.
If you don't have any equipment at all, it'd cost you the same to get all your stuff together that you would need to restore them as it would if you bought replacement ones(this type of BBS rim). If you know someone that has the compressor and paint gun then You'd only have to buy the paint, activater and clear coat (primer as well if you want to do it right). Plus paying to have them either sand or glass blasted. Fun project, but time consuming to do it right.
Having them powder coated is another option. They chemicaly strip them, the powder them. Set of 4 could be around $300 or a little less at the cheapest and up to $400 depending on who would even do it.
